PrelateBishop
Here is the gear in question:
- 3Com 3CRWE554G72TU OfficeConnect® Wireless 11g Cable/DSL Router --> LINKY
- MSI PC54G2 Wireless IEEE802.11g PCI Card Adapter --> LINKY
The router has the most recent software upgrade (v2.01.10) and the wireless card was installed using the most recent drivers (v4.3.0.0). Operating system is Windows XP SP2 with most recent updates. The MSI card appears to be installed properly as it shows up in Device Manager without any issues.
All wired connections to the router are functioning properly. The wireless capability of the router has been enabled. Encryption is NOT turned on. The PC also has a 3Com Etherlink III 3C590 ethernet card installed that is functiong properly (I have also tried disabling the card to see if that helps).
I absolutely cannot see the wireless network at all. The card and router are set to the same channel and the SSID has been manually typed into the settings of the PC.
HELP!!
HELP!!
