In addition, secure your LAN with software Firewall on each computer. Allow LAN communication between your computers only. By doing so, if someone did manage to "leech" onto your Wireless he would be able to ?steal? Internet bandwidth but would not be able to access your Hard Drive.
If you have real Sensitive Data, use it only on a Wired Computer and segregate your wired computer from the Wireless.
I have 3 computers at home. Two of them are connected on a 100mbits switch. I recently installed an HTPC (3rd PC) in the living room and I simply want to be able to access shared files on one of the wired computers. I bought a simple wireless router and a usb dongle.
I do not use the router to access the Internet (I can already establish two connections to my ADSL provider at the same time with the switch (so I get two differents external IP adresses and don't have to mess with the whole portforwarding stuffs). Basically I just want to use the router as a bridge between the HTPC (wireless) to a main computer (wired). I'd like to make sure that my LAN is safe and that I can access the media share only (Internet not needed) via wireless.
Buying two USB dongle might have been easier but the router + dongle was really cheap.
