- Jan 27, 2002
- 5,385
- 0
- 71
I just hooked up a wireless netgear router w/a 4 port switch (mr814v2) into my wired network. I also have a wireless card for my laptop. I went thru the router and enable 128 bit wep, did the wireless card access list. Is there anything else I need to do for more security? I thought I read somewhere about turning SSID off so it is not bradcasting. Is this true ?
Also the wired network is behind a Linksys router. On the wireless router I disable the DHCP ( was told to do this so I could see the wired network). I can go online no problem but cannot see the wired network.The ips and subnets are different. I did the ipconfig release and renew and cannot not set the ip cause that would scew up my cable modem Can anyone help w/ this Thank you
