Originally posted by: Matthias99
Define "don't work". Are you getting a green light, but no data back and forth (check your cable, or try another port)? Can you talk to the router itself, but not the other systems on the network or the outside world (check your network settings)? Can you see the router, but you can't get DHCP to bind (try it with static IPs)?
You might also want to try the Networking forum.
sorry, i should have been more specific.
the router's green "connected" light is on. i've tried to use my laptop's ethernet port to connect to a different port (w/ a different cable) but it didn't work.
i can not talk to the router via my wired desktop, but i can with my wireless laptop. (getting into the admin stuff, 192.168.2.1, i assume)
when i try to "repair" with windows, it says it failed to renew an ip address.
In my experience, that's usually a bad cable (or you're trying to use a crossover cable instead of straight-through), or a bad port. But you said you tried it on multiple ports, and with a different cable, so that's probably not it.
Are you sure the Ethernet connections on the desktop/laptop work (ie, they've worked before)? Are they showing a live connection (it says it's "connected" to something)? Have you ever used this router in a wired configuration before? Did you try resetting the router?
You can also try turning off DHCP on the host side and manually setting it to an IP in the correct address block (usually 192.168.1.X, netmask 255.255.255.0, but check your router's documentation or see what the laptop picks up on the wireless). If all the hardware is functioning, doing that should let you get to the admin pages on the router (go to
http://192.168.<your router's address>/).
Invariably, these problems are always something dumb... it can just take a while to find it.
