Wireless Router Help?
james182
48
I'm trying to setup my Linksys wireless router. The installation cd does not work, it tests my internet connection and then tells me I don't have one. I was trying to setup the router by going to http://192.168.1.1 and doing it that way but I was having little luck. I was able to get it so that the wireless card was connected or could "see" the router but it said the router was not connected to the internet.
How do I know if I have a static or dynamic IP? I'm at school trying to use the school's LAN.
Do I have to enter a domain on the page at http://192.168.1.1?
JackMDS
29,545
422
Quote: "How do I know if I have a static or dynamic IP? I'm at school trying to use the school's LAN".
Well I doubt that we can know Waht is the nature of the Network in your School.
However I bet you that the Nice Network (IT) people will tell you the parameters of the Network if you ask nicely.
:thumbsup:
HappyPuppy
16,997
:thumbsup:
:Q
ktwebb
2,488
And there it is. The problem and the answer. The Schools network. Might want to ask them if you can use a personal NAT router on their network. If you can then surely they would be willing to help you set it up right?
