wireless roulter & wireless usb NIC
chuckieland
is possible to mix brand
i have d-link 624 Wireless roulter
i'm thinking to get SMC wireless usb NIC $38CAD
would that work? or is better to stick with the brand?
It is possible to mix brands.
However you cannot mix 802.11b with 802.11a. (unless it is dual a/b or a/g)
You can mix 802.11b with 802.11b 802.11g. (g is backwards compatible with b by definition)
It is easier to gaurentee compatiblity with same brand, but they SHOULD work together.
