Wireless reliable?
Sniper82
16,517
When downloading big files how reliable is wireless? Seems like you could get files corrupted sometimes? I am a newb to wireless. Getting a complex(I thinks the name of it) router and am thinking about going wireless completely. Anything I should know?
Figured I would start off with 802.11b since its cheaper and I don't transfer files from PC to PC I just share the internet with a couple other PC's.
MDE
13,199
It's fine as long as your equipment doesn't suck. I've downloaded Linux ISOs without a problem over my wireless connection.
Sniper82
16,517
What if the PCI wireless NIC is a different brand from the router? Does that matter?
MDE
13,199
I have a Buffalo NIC and Linksys router, working just fine. It's the beauty of a true industry standard :).
shaowq
33
the router for the B version would be cheaper but i would really go for the G version. B = up to 11mb/s and the G version is up to 54mb/s. On my laptop i just went from B to G and IMHO G>B. Connection strength/signal strength is so much better. You don't drop signal as much. You don't need to get a great wireless card just get a good wireless router. Get a linksys or netgear or something like that and you should be fine.
JBT
12,094
I run an Intel mini PCI card and a D-Link DI-614+ They run perfrectly. I have uploaded and downloaded GB's from my laptop with out problems so I wouldn't worry about data corruption. I am pretty sure they have things in the wireless standards to prevent that. Thats one reason that there is so much over head. IE 802.11B is spose to be 11Mb/s but in reality if you are getting 5Mb/s your getting great speeds.
Engelphat
77
my school is now all wireless, we do everything off of it, and i've downloaded a bunch of big files at jfk airport. you have nothing to worry about
