You need to be able to put two directional Antenna (one on each site) that are facing one the other and have a direct line of site.
Depending and your internal environment and your selection of Bridging settings, the Antennae should be connected to a Wireless Cable/DSL Router or an Access Point
This page has info about Bridging options, what have you choose has to be adjustment with your selection of external Hardware (Antennae).
