wireless problem, please help!!!!
garytmib
i have a d-link di-614+ router and a siemens usb antenna. this is the third router i have tried to resolve this issue. i can get a connection with the antenna but lose it after about five minutes. i also lose my internet connection on the computer wired to this router. all i have to do is reboot the computer and i regain my connection. 4x mode has been disabled on the router and does not help. if i remove the router i never lose my connection, so the cable modem is fine.
any help is greatly appreciated.
thanks,
gary
can you clone your MAC address in your router ?? Use the same address as whatever PC you used when you initially connected directly to the cable modem.
If the wired connection on your router doesn't work, you can eliminate any wireless issues for now.
THe problem has to be in your router setup. Make sure it's setup correctly and then check your internet connection before you boot up any PCs, to see that it stays connected.
