- Oct 24, 2001
- 184
- 0
- 0
bout a month ago I bought an abit IC7 and a P4 2.4C. Put it all together, but had a little problem with my wireless nic, a d-link airplus 802.11b. When I first install the card as per directions, i get little freezes for about 3-5 seconds and then it will unfreeze for 3-5 seconds and keep repeating the process until I have gone into the network program and gotten it to connect up to my router. Once its connected its fine, but any little pause in the connection will cause a little freeze. I didnt think this was a problem until I tryed playing a game online, after a while eventually playing online I would I assume get one of these freezes because my computer hard lock and sometimes just crashes to a reboot. I then decided it must be my card, which ran fine in my old box I might add, so I went and got a netgear usb wireless. Well, same problem, so now I am sure its just that I got a bunk board. I sent it back and got it back today. With a full reinstall of XP I get it again. I had tried every driver for it that I could, new board bios, all windows updates, nothing helped. I have tried any bios setting that has to do with pci stuff but thats not helping either. I have looked through the XP event viewer and only found this error:
The COM+ Event System failed to fire the ConnectionMade method on subscription {4515EE1C-7D96-4424-B0AF-D653A4E89199}-{00000000-0000-0000-0000-000000000000}-{00000000-0000-0000-0000-000000000000}. The subscriber returned HRESULT 80004001.
Not sure if that is related or not. I am now assuming its and XP problem maybe? But i was running XP with my old board and this card just fine I have yet to try wired networking as I dont have a cable long enough to reach my router but I will maybe try tomorrow.
Thanks
Thanks
