Wireless Piggybacking / Bridging
Padilla
50
Hey all,
Im trying to get my D-Link 802.11g AirPlus Xtreme G Wireless Router
Model: DI-624 (router A)
To connect to a Linksys 802.11 (b I think) Model BEFSW11S4 v2/v3. (router B)
What im essentially trying to do, is have router A connect to router b (which has the a LAN connection to the internet. because the signal I get from router B is weak at human height level, so I got up on a ladder with my laptop almost to the ceiling and got great signal from my brothers upstairs.
So what I did was mounted router A to the ceiling in this nook in a closet, whereas I have "Excellent reception" to router A.
What would be the process on setting up router A to establish a connection to router B
to essentially (ride / piggyback / extend) the network. In order for my to be able to use my laptop with a stable signal.
Thanks in advance!
JackMDS
29,563
432
BriGy86
4,537
well i know you can have 2 routers connected through a hard wire and have it work if you enable RIP (don't know if it works with wireless) and some routers i believe you can change their function, such as changing it to an access point, bridge, or repeater
Padilla
50
JACKMDS,
I also have the ability to change router A to a Belkin 802.11g which has the WDS function in which you speak of. Would it work then ?
JackMDS
29,563
432
Originally posted by: Padilla
JACKMDS,
It might work you should give it a try.
Why Might?
WDS would work for sure with another Wireless Router of the same Brand. Across Brands(depending on chipset) it not always working.
:sun:
