Originally posted by: amdskip
None, I vote for a usb wireless adapter. Most of the time your tower gets shoved somewhere restricting it's range.
TrueOriginally posted by: xSauronx
you know you *can* buy an antenna with a length of cable that you can set elsewhere.Originally posted by: amdskip
None, I vote for a usb wireless adapter. Most of the time your tower gets shoved somewhere restricting it's range.![]()
Originally posted by: JackMDS
If the wireless computer is few feet away from the Router then any PCI with the as is Antenna would do.
LOL, do not be so concrete it is an Example to make a point.Originally posted by: skreet
Sorry, but if the wireless PC is only a 'few feet' from the router, why are you spending $50.00 on a PCI adapter, hardwire it...
And there are good cards out there that come with such an antenna.![]()
Originally posted by: chuckm
I just set up my wireless and am getting great results from this one;
http://www.newegg.com/Product/Product.aspx?Item=N82E16833315041
I don't believe you can do better for the money.
Chuck
