Wireless PCI card or Wireless Bridge?
mcloud777
120
I am having trouble getting a vista capable pci card to work with my pc so I can connect to my parents wireless network. I wanted to know if it would be easier to just buy a wireless bridge and connect it to my pc since it would not require drivers correct? I know nothing about wireless bridges so my knowledge is limited I just heard it might be an alternative to buying a wireless pic adapter.
JackMDS
29,539
418
I do not know what your Wireless PCI problem is, there are many cards that do well with Vista.
Example, Edimax - PCI http://www.newegg.com/Product/...x?Item=N82E16833315041
However, Wireless Bridge is a good thing too.
The readymade Wireless Bridges are expensive and they can only work as a Bridge.
Many people here buy a Wireless Router, flash it with third party free firmware and configure it to work as Wireless Bridge.
Example, this Wireless Router, Asus WL-520GU
http://www.newegg.com/Product/...x?Item=N82E16833320023 , can be flashed with this,
http://www.dd-wrt.com/wiki/index.php/Asus_WL-520GU
Then be configured easily as a Bridge, http://www.dd-wrt.com/wiki/index.php/Wireless_Bridge
Madwand1
3,309
Yes, this is correct. A wireless bridge can take some effort to set up for the first time though, especially if you go with third-party firmware. However, once you get over that initial setup, it's all payback -- changing to another OS, another PC, multiple devices, etc., are much easier and potentially cheaper than buying additional wireless adapters and configuring them.
The D-Link DAP-1522 is a new kid on the block in this category, and it's got some nice-looking specs.
http://www.extremetech.com/art.../0,2845,2310360,00.asp
Here's a review of it being used as an access point, which shows some of its limitations:
http://www.smallnetbuilder.com...iew&id=30455&Itemid=96
