Wireless PC sharing files on Wired PC
How do I share files between 2 computers? One is wireless, the other is wired. Both are connected to the same wireless router - one with cable, the other sans cable.
Thanks in advance
Match the network group, then share the folders.
BUT, if one is not a XP or 2K, then you need to add 'sharing printer and folder' option from original OS diskette!
OR, use network 'wizard' in MS.
Good luck!
