Wireless PC card question
JackMDS
29,545
422
Yeah the Wireless Card in the combo is a PCMCUA Card for a Laptop.
You need a Wireless PCI or Wireless USB to connect to a regular PC.
There are very few combos offering of Router/PCI or Router/USB. You have to buy the components by them selves (the combos are not much cheaper to begin with).
Link to: Wireless What Should I Get?
:sun:
EdfromCocoa
121
I recently bought a Belkin Pre 802.11N wireless router with the PCMCIA card as a kit for $200.00 at COSTCO. It has 3 antennas (linksys, dlink, and others have come out with kits too). Called Belkin support from costco BEFORE I bought the kit to check on them. They answered my questions completely. I run WPA, something I could never get to work with a DLINK 802.11g router and PCMCIA card: their help desk never answers the phone. I get 108.0 MBPS consisdtently and I can go onto my metal screened in porch without losing he signal.
Ed
kevnich2
2,465
8
What router options does your belkin pre 802.11n router have, ie, static DHCP, Qos, etc? Also, what's the real world speeds of your router, let's say you transferred a 100mb files with the wireless, how long does it take?
