- Jan 5, 2013
- 11
- 0
- 0
Hi folks. So I'm a bit confused about what is so great about the 5Ghz wireless. I have a dual band router and I have always used the 2.4 band. This is because I did testing about a year ago and determined that all the places in my house that I use my wireless on a regular basis produce less speed in network tests I have done when using 5Ghz instead of 2.4Ghz. I understand that the higher frequencies have less object penetration and shorter distances so should I conclude that 5Ghz band is only better when I'm right near it? Also, when I'm close to my router and doing my tests, I see the same speeds from both bands so theoretically I never really see a difference. The only thought I had was that maybe using the 5Ghz band provides better error correction or better stability in some way. Am I missing something? Thanks.
