Wireless NICs?
AMDPwred
3,593
I'm looking to buy a laptop for college and I'd like to use wireless internet. Which NIC should I go with? What's the difference between 802.11a and b? Anything I should be aware of?
SteelCityFan
782
a - 55Mbps
b - 11Mbps
All depends on range and if the access point / router supports the newer 55Mbps speed. Price will be much higher for the 55Mbps as well.
I just bought the Linksys Wireless Router / NIC.
The NIC I got was version 2.5 which was the latest until I just noticed they have a version 3 out. I have heard from a few people who upgraded from version 1 to 2.5 that it was a good improvement. Only problem was that the model number stayed the same, so when I was ordering, I did not know which I was going to receive. I ordered both from Dell with a $25 off $200 and a 10% off coupon (http://www.hotdealsclub.com had them listed) .
I ended up getting the newer 2.5 NIC, and the older Version 1 Router. Both work as well as I need them to. I only live in an apt, but I receive excellent signal quality from anywhere in the Apt. This of course will vary home to home depending on how many walls are between you and the router, etc.
Suki
289
AMDPwred - you better call your school before buying that wifi because 802.11a and 802.11b are not backward compatible to each other. They used different spectrum range.
SteelCityFan - we have pretty much the same setup. I bought the d-link 714 and loving it.
Desktop:
P3 600@800
P3v4x
AIW 8500dv
384 meg RAM
Laptop:
P3 700
Model: T20
256 meg RAM
AU Tiger
4,280
If going with 802.11b, Orinoco Gold cards are generally considered to be the best available cards. I have two myself and they both perform much better than the D-Link I tried before switching.
