Wireless NIC Problem, Any Suggestions?
Playmaker
My sister has a computer from Best Buy that is about a year old, with the service plan. This summer she wanted a wireless NIC so I bought the Linksys Wireless-G desktop card for our Linksys Wireless-G router. After installing it, the computer would freeze at the first splash screen and not POST. I could get into the BIOS, but other then that it would not boot up. With the card out, it works fine. I had the same problem with all open PCI slots. I brought it into to Best Buy thinking they'd send it in to get the motherboard replaced, but the guy suggested I try another card first. I exchanged the card for another Linksys and had the same problem. I brought it in again today and they tried a Netgear card and it worked fine. He said the Linksys cards must not work with the computer.
My questions...Would a D-Link or Netgear Wireless card affect range/performance at all given that the router is Linksys? Does this "Linksys cards don't work in this computer" answer sound plausible? Or would replacing the motherboard fix the problem? The D-Link cards are sold out and the Netgear cards are more expensive than the Linksys, so I'd rather just get the Linksys to work. Any advice is appreciated.
Let us know what mobo it is in, we may find issues with it. I generally only use USB wireless nics as i find them to be more reliable and I dont have to open my case if I get issues like you are getting. I find that the less than is installed in the case/mobo the less can go wrong. USB rocks.
Is the D-Link Wireless-G USB card decent? Would there be much of a difference between it and the Linksys or Netgear models? It is the same price as the PCI Linksys card, so that would work out great.
You can mix and match brands without a problem. I'm using a Netgear 802.11g router with a Broadcom 802.11g chip in my laptop and a D-Link 802.11b card in my desktop without a problem.
