Hi,
Am just trying out wireless networking for the 1st time...and have plugged a couple of Netgear MA101 USB adapters into a Win98 P3 machine an a WinXP Pro XP1700+ machine.
It detects the network which I have named "Trevillion" but does not allow me to browse it, keeps referring me to the "Network Troubleshooter" etc. I think I have set it up correct at both ends but it's not exactly easy as the WinXP machine uses a built in configuration panel while an extra Netgear one is installed on the Win98 PC during driver install.
Any tips? Security is off at the moment because it kep saying "Disable encryption to join network on the Win98 PC"
Thanks,
Jamie
Thanks,
Jamie
