Wireless newb questions
Wolfchild
Okay my existing setup was a cable broadband connection, Linksys wired router and three PCs around the house.
The other day I bought an almost-new laptop with some with a Dlink Extreme G bundle (router and laptop card). In the interest of testing everything out quick I just plugged the Dlink router into the uplink on my Linksys router, and got the laptop's wireless card up and running quickly.
Now my questions. Should I be moving my other PCs over to the wired ports on the wireless router? Or would it not really be any faster than the existing router since it's just a regular broadband connection.
If I had three wired devices on the new Dlink Extreme G router, how many wireless devices can I have on it (I have just one now, more on that in a second). Only four total? Or is it unlimited on the wireless side? (It's only me and the wife here so really only one wireless PC would be used at a time). The manual is not telling me if there is a limit on the amount of wireless computers I can hook into this.
The reason I ask the last set of questions is that I have some PCs in the basement too, not hooked up to the internet right now. One is a permanent computer and the rest are ones I am putting together for friends. I'd like to put a wireless PCI card in the permanent one and get a wireless USB card to temporarily hook the others up to the internet. Should I make sure to get another Dlink Extreme G card for the permanent computer and the Dlink USB adaptor for the other temporary hookups?
Any of this make sense? If anyone has any suggestions I'm all ears.
minendo
35,560
22
Doesn't matter. Just remember you can only have one of the two act as a router. The other would be a switch or access point. Personally, I would just remove the Linksys router and run everything through the DLink.
You are limited to the number of IPs your router can assign.
Does not matter what brand you get.
