This week I would buy this Wireless Router.
SleepSteam 2626Wireless Router.
There is $30 rebate which bring the price down to $47. (Else where it is sold for over $120).
Then I would find the cheapest place that sells Orinoco Gold Client.
It will cost less then MS, and you will get better Wireless performance.
Why?
Given what ever Access Point, or Wireless Cable/DSL Router, you have, among the Entry Level 802.11b cards the Orinoco PCMCIA Gold is the champ.
One of the ways to augment Wireless is by using a better Antenna then the stick that come on the regular Wireless hardware. The typical "stick" is about 2.2dbi, a good Antenna would be 5dbi and above.
While most of the Access Points have a removable Antenna, most Wireless Cable/DSL Routers do not.
The Speedstream 2624 has two advantages.
1. The Antenna is removable.
2. The original Antenna is 5dbi.
Otherwise I would go with the decor:
If you need Blue, get Linksys.
Nice Gray a Silver, get D-Link.
Futuristic look, get Belkin.
Stylish, get Microsoft.
Battleship Gray, get SMC.
In otherwords ther is no real differences between the above.
