- Jul 1, 2002
- 4,570
- 0
- 0
I am using a netgear MR814 v2 router
And a dlink dwl 122 wireless card
Connection is wonderful, very fast. I have it set up as open network (this is the only way it will work wit the card I have tried shared) with 128 bit WEP that cycles through 4 keys, as well as access restricted based on MAC address.
This all works wonderfully, however I can't get anything to connect to the router unless it is broadcasting the SSID. Now, if I turn off the SSID once other pc's are connected, they stay connected just fine.
And yes, I do have the SSID nake setup on the all PC's identically to what it is on the router, and it is a new SSID not the one that comes default.
Any ideas?
Thanks!
oh yeah WinXP pro on both machines. no service pack 2
Any ideas?
Thanks!
