Wireless Networking Problem
maxtuh
7
Hi all,
I have the following setup and my internet is being shared
Desktop computer
Laptop computer
I have a microsoft wireless router , this is the following info i got of it:
Local Area Network (LAN) Settings
This section displays a summary of settings for your LAN.
Local IP address: 192.168.2.1
Subnet mask: 255.255.255.0
DHCP server: Enabled
Firewall: Enabled
DHCP Client List
This section lists the computers and other devices that the base station detects on your network.
IP address Host name MAC address
192.168.2.11 meena-9fic8d6d0 0x000d3a23d577
192.168.2.7 monish-4ah2kmgv 0x0000210341ff
Base Station Information
Runtime code version: V1.11.017
Boot code version: V1.06
LAN MAC address: 00-0D-3A-24-E9-30
MAC address: 00-0D-3A-24-E9-31
Serial number: S333012360
OK, well the internet is fine when shared, both are connected to the same workgroup and both run winxp pro, i tried pinging the laptop it works fine, but when i try to acess the drive and double click on any folder or file it says the "does not have permission, contact admin or something"
Can someone help me out ,PLEASE, i have been frustrated since 7 days trying to share the files between computers!!!
maxtuh
7
i did share all drives, i am using winxp pro both computers with ntfs partitions, i think its something to do with the shares
both computers are admins?
so i am not sure how to proceed.
Just a side note:
The desktop is connected using broadband DSL to the router with a cable and the laptop has the wireless card.
THE WIRELESS ROUTER IS MODEL MN 500 from micorosoft.
Schoolies
On any computer, right click a folder go to the Sharing tab, click Share this Folder and give it a name.
On the other computer, go to Start, Run, type two backslashes and the computer name of the machine you just shared the folder on.
Ex: \\laptop
If it asks for a username and password then enter the username and password of the administartor account to the computer that has the shared folder.
If your having problems, turn off Windows XP firewall and make sure for some strange reason you don't have the Security tab set to deny access on that folder.
maxtuh
7
Ex: \\laptop
thx for the reply ,
there is no firewall running under XP i have disabled it on both computers, both have the same workgroup? but the funny thing i can see all the drives on my desktop computer, but i cant see the desktop computers drive on the laptop, nor can it find the workgroup for some apparent reason when i click "My workgroup" link
btw i tried to punch in the name which is "\\computer" it says no such computer exists???
Schoolies
are you able to view the shared folders if you go to Start, Run, and type " \\(other computer name) " ?
RBBRMADE
491
I know you stated you checked, but double check your ICF (windows firewall).
Your issues are exactly that of the firewall being enabled on one machine.
Do you run Norotn or McAfee Internet Security?
Ron
