Wireless networking help
The Green Bean
6,506
7
I have a "homechoice" box which is connected by a DSL telephone line. It then connects my TV, and has two ethernet ports, labelled NET, and PC....I have a PC connected to the "PC" port...
I wanted to add interent connection to my local wireless network. Possible? how?
I already have an ADSL modem cum wireless access point. Doubt itll help since it will only feed my internet needs.
40Hands
5,042
If you have a wireless router then you should be able to connect the "PC" port to the WAN port on the router. Then connect your computer to one of the ports on the router.
The Green Bean
6,506
7
So ill need a broadband router? I have an ADSL router and ADSL line, but they are currenty connected to a "box" which gives me both internet and TV signals.
thnx
JackMDS
29,545
422
I am familiar with most of consumer Internet connection settings, and frankly, I can not make ?head and tail? of what you have and what you would like to do.
Might help if you would provide a better more detailed description of your situation.
:sun:
The Green Bean
6,506
7
:sun:
sorry :p
Ok i have somekind of a router where my DSL line is plugged into. From there, I get my TV connection through a scart socket and internet from the PC port (RJ44). There is also a NET port which is not used.
JackMDS
29,545
422
Assuming that your source is a combo Modem/Router.
Get a Wireless Cable/DSL Router and connect it to the Modem/Router using a regular port (leave the WAN port of the Wireless Router Open).
Plug all your Wired computers to the second Router's ports and use the Wireless.
The second Router has to be configured as a Switch with an Access Point.
Instructions here: Using a Wireless Cable/DSL Router as a Switch with an Access Point
:sun:
The Green Bean
6,506
7
I did what you said, and the PC thats connected via RJ44 on the ADSL router works fine. The PC ith the wireless connection detects the network but the internet on it doesnt work?? WTH??
The Green Bean
6,506
7
I tried copiying all the settings from the wired PC to the wirless one (TCpip, DNS, IP, gateway etc.) Still doesnt work. There is aflow of traffic but no internet! Why?
