Unfortunately I already have a 2.4Ghz cordless phone that uses FHSS at home and now want to setup a wireless network. Also have a microwave but have tested that it doesn't affect the phone signal at all so it's probably adequately shielded.
I know the phone is bound to cause interference in the 2.4Ghz wireless space, but I want to see if it is possible to setup a working network with it, instead of having to go out and buy a new 5.8 Ghz phone.
The phone base is setup around 1 ft off the floor to one side of the hall. My thought is to setup the wireless router high up on the wall (say 6 ft off the ground) in a passage at the end of the hall from where it will have line of sight into a third of the area of each of the 3 rooms and fully into the hall/ dining area.
I know the easiest answer would be a simultaneous dual band 802.11n wireless router but from the Newegg end user feedback on these products they don't look very stable or well performing, with some problem or the other reported on every model.
So am thinking of a 2.4 Ghz 802.11n router and hope the setup alleviates any problem.
One more thing, from the sticky I can see that the antenna on the wireless router should point straight up (i.e parallel to the ones in the clients). Some of the wireless routers e.g. Linksys E3000 have no external antenna and yet their orientation for wall mounting and placing on a flat surface are different so how does that work out?
And if the router has external antenna, can I point them straight down instead of up (needed to get line of sight into the hall area).
