Originally posted by: joedrake
It says I'm getting 54MBPS, but then again - I'm 7ft away
Edit: Any updates on that lottery ticket?
Originally posted by: KLin
3:38 to transfer a 178 meg file from my desktop to my 802.11g laptop. That's slow 🙁
How quick is your laptop hard drive please?
Originally posted by: spidey07
54 Mbs.
54 Mbs.
Pics for proof because I don't believe you unless you are using one of those dirty 2 channel hacks like speedboost or whatever and even then it'd be interesting to see a screenshot.
Managment frames make 54mbps throughput impossible on standard 802.11g equipment.
54 Mbs.
Managment frames make 54Mbps throughput impossible on standard 802.11g equipment.
54 Mbs.
Well that's how fast I move data. Throughput is a hole nutter question.
5400 RPM Fujitsu.
Haha define what you thnk throughput is then.
Throughput is one way data transfer of the payload. Normally disregarding layers 1-6.
5400 RPM Fujitsu.
This is why in my opinion.
I bet a 7200 rpm hard drive in your laptop would help speed up file copying over to your laptop a lot.
Though the disadvantage is more heat, less battery life, and you can't always get 7200 rpm laptop hard drives in the same size as 5400 rpm hard drives, well at least not the really large ones yet. Hey I could be wrong.
Originally posted by: Imdmn04
The real throughput from experiences are somewhere between 10-15Mbits/sec, thats with WPA on on a G router.
