recently did some work at my parents since they got cable internet. Used 2 MS MN-500 802.11b base stations (wireless/router station)
one station to act as the primary router from the cable modem, one station to act as a WAP.
connected to router 1 are 3 pcs over cat5 and the crossover cable going to the MN-500 as an AP. two wireless clients in the home (one laptop with a pcmcia card, one pc with a usb adapter)
heres the problem:
all pcs connected over cat5 work fine, no problems.
the wireless clients however, have random problems. they always see the WAPs and get strong signals. they always get their IP from the main router. they say theyre all connected properly to the network. however, even with the proper connections sometimes the wireless clients just dont connect to the internet.
it looks completely random. i restarted the pc with usb adapter 3 times the other day, each time having no problem getting online. so i come home and the next day my sister calls, it wont get online. i have her read me the IP address and DHCP server address. everything is connected like its supposed to be. i didnt have time to go fire it out or look at it...but she calls me back an hour or so later, and says its working, she didnt do or change anything.
so what the hell is going on? i get the same situation with the laptop with pcmcia card. they call, its not working. later in the day, they call...it works fine and they havent done a thing except tried again.
is this some common problem with wireless networks? i was wanting to avoid running cat5 all over the house, or rather, in the new house theyre moving in to. but if i keep getting these problems im gonna have to.
usb adapter is an Epox (forget model)
pcmcia is a SMC
any ideas?
EDIT: pretty sure the cat5 conecting the router to the AP got messed up somehow, dont have a line tester so ill go get it tested tomorrow by a guy i know, but i was trying to log into the ap and it worked intermittently
new cable and it worked fine, every time....pretty sure this is the problem
thanks though guys, i will keep this stuff in mind in the future
(as well as better protect the cat5 i run)
heres the problem:
pcmcia is a SMC
any ideas?
