- Feb 10, 2001
- 9,837
- 0
- 0
Hi all,
I work for a certain very large PC superstore in the Kent area, UK (I'm sure UK folks know who I'm talking about..."where in the world...")
and we're trying to get a wireless network going in the store, won't bore you with why.
Machine A is a new PC which is connected to the internal store network (Cat5->wall) and goes from there to the 2Mbit ADSL line and the corporate intranet. High-spec, running WinXP Home, with one of these wireless adaptors.
Machine B is a WindowsME machine (for testing purposes, I hate ME, argh!), also high-spec, with also one of these adaptors.
I've got the LAN & Wireless connections bridged in WinXP so that the ME machine can not only get on the 'net, but the intranet too. It works fine for about five minutes, then the connection cuts out (no more data received by B), a reboot sorts it out.
I've eliminated Machine B by trying a WinXP Home laptop, that also cuts out after about five minutes connected. The connection still shows that it's active, but no more data is being received by machine B.
I called netgear tech support (a tech calling tech support, how humiliating...!), the French (sigh, this took a looong time) guy said to try hopping to another Channel and dropping the transmission rate to 5.5Mbps from 11Mbps. However, you can't do this under WinXP because only the drivers are needed and therefore are only installed. On ME or under, the utility is installed which means you can change channels and speed etc.
So- how can I get Machine A's connection settings changed as I can't use the netgear program? Also, why the hell is the connection screwing up after about five minutes data transfer? It can't be the distance, as the two machines are about thirty feet away, with only a glass partition between the two, which really shouldn't be messing things up, as the laptop I tested was *next to* Machine A when testing. Changing the data rate shouldn't be the fix, as it's set on Auto anyway (have tried it with 11Mbps).
If anyone could help, I'd be so grateful,
Thanks,
Dopefiend
Thanks,
Dopefiend
