i am new here so please be patient.
prob: can see my laptop in network workgroup but i cant gain access. and when i try to view work groups on my laptop i get ms home not accessible, see admin for permission network path not found.
i did: set up through wireless wizard. did home network wizard i even put the info on s/d card the way it says and still same. all file share options are checked.
i can surf but no file or printer share.
i have. desktop
xp box with sp2<added after prob started to see if it would help>
lynksys wireless g router
cable modem
laptop
same as above but 802.11b/g
i am pretty good getting around a pc but try to be spacific.< you dont have to say click start go to prog and such>
any help would be greatly appreciated.
