Here's the deal folks:
Moving home for the summer. Need internet access, will die without. 😉
Comcast cable modem set-up already in 2nd floor of house. Problem is, I am moving to the basement (2 stories down, probably opposite side of house). I believe wireless is my only option, because running ethernet cable to the basement would be impossible. Getting a second cable modem and connection run to the basement would also be costly.
Assuming this to be correct, what wireless solution is best for me? I am assuming an 802.11g router/access point would be a good investment for the future (wiring an apartment or something). Anyone know which router or access point is best for long distance? I kinda like the Dlink DI-624 AirPlus Xtreme G series High-Speed 2.4GHz 4-Port Wireless Router . However I have heard mixed reviews about the D-Link brand. A router with integrated ports is a definite plus.
Also, what kind of card should I get for my computer in the basement? I know USB are better for connection, but I only see them available in 802.11b varieties. Is this my best option, since I have such a long distance to cover? Or should I go with a PCI 802.11g card, since the technology is more current?
Please help!
Please help!
