I have an ISP provider that insisted on a Fiberoptic conversion (from DSL) and ever since they "upgraded", I can't get to the Internet from my office (the garage), which is about 1000 ft and four brick walls away.
I tried installing a Netgear EX7000 wireless signal extender and set it up as an Access Point. This unit is dual band, but I noticed that my computer can see the Ex 2G and 5G networks that I created only when inside the house, but only the 5G when outside in the garage, so when I connect to the 5G from the garage, I can't get to the internet.
I can only get internet via the original base router or the 2.4G on the EX7000, which are only available inside the house.
I found out that the base router from the phone company is only 2.4G, not 5G, so a more powerful EX would not solve the problem because those also require 5G on the base/main router for the distant signal to work, right?
I called my phone company (ISP provider) and they recommended a "Video Bridge" that they say will "convert" their router from 2.4G to 5G, which then will allow the EX7000 5G Network I created to see the Internet and then I should be able to get Internet from the garage through that EX7000 5G Network.
Is this the right way to solve this problem?
I didn't know Video Bridge could work as a 2.4G to 5G band converter.
