I'm wanting to set up a wireless network at my house. I have a DSL connection through Sprint/Earthlink that I obviously want to share. I have 2 desktop computers that will always be part of the network, with the occasional visiting laptop.
The first computer will connect to the router with a cable, and the second computer will connect with a wireless connection.
For the router I think I've decided on the Buffalo WHR-HP-G54. From what I've read it's a good reliable router even with the stock firmware, which is a plus because I don't want to flash it. I'll still take recommendations on a router though if there is something better
I need recommendations on a wireless PCI card for the other desktop though. Should I just go with the matching Buffalo PCI card or is there something better you guys recommend?
Thanks
Thanks
