- Dec 24, 2002
- 59
- 0
- 0
I've just got a Buffalo WHR-HP-G54 router. I have flashed it with the latest DD-WRT firmware and all seems to be working ok, but not when it comes to the wireless.
For no good reason, the internet just stops working on my PC which has the wireless set-up. But the signal strength does not change and is still pretty strong at about 60%. I'm using a Netgear WG311 PCI card. It's fine one minute, then will just drop out. I can often get it working again by using the 'repair' function.
The net connection is fine on my other system which is plugged directly into the router, and as I say, the wireless connection itself still seems to be healthy and active as I can see the other system in the DD-WRT control panel.
This happened before I upgraded firmware, so that's not to blame.
I have been told it could be a cordless phone that's causing it to drop out, but it regularly happens at 2-3AM in the morning, when my phone and any neighbours phones are surely not in use. Unless a phone can interfere when not in use? I have tried switching channels which all operate at slightly different frequencies anyway, but that makes no difference. Neither does having security enabled or disabled make any difference. I'm at a total loss to explain what is going on here, and it's quite frustrating!
Any ideas...?
Any ideas...?
