wireless microphone ..
Kaido
Feb 14, 2004
50,526
6,622
If your dSLR has mic input, you can just use a lav mic instead (a small clip-on mic on a wire). This one has a 20-foot cable & is super small:
https://www.amazon.com/Audio-Technica-ATR3350iS-Microphone-Smartphones-19-69-Feet/dp/B002HJ9PTO/
Wireless systems are expensive & don't work as well as wired or dedicated audio recorders. Alternatively, you can use a video editing program to do an automatic audio sync from two different audio sources. So have the dSLR record the audio & then hold a portable audio recorder in your hand. The Zoom H1 for $99 is a great handheld model:
https://www.zoom-na.com/products/field-video-recording/field-recording/zoom-h1-handy-recorder
That's more work than just plugging a mic into a camera though.
