- Jun 23, 2005
- 15,916
- 4,960
- 136
Windows 7 64
Intel i5 2500
gskill 8gb ddr ram
radeon 7770
h77m motherboard
Sometimes my keyboard and mouse work fine, other times I can be guiding the mouse in one direction and the pointer moves but then stops for a couple seconds then moves again. Like it lost sync for a moment. Sometimes they go through bouts where they won't work at all. They're all Logitech, for what it is worth. Keyboard is K400, first wireless mouse is M-RBQ124 the other mouse I use by the couch is M185. I use them when I'm on the couch about two meters away from the PC. I use signal enhancing usb sticks to plug the wireless receivers in.
Sometimes the keyboard and its touch pad will work great while one of the mice will not. Sometimes it's the inverse. The one non logitech input device I have is my gigabyte mouse on my desk and monitor. I have had no such problems with it, but then again it's wired directly into the PC. I'm afraid the usb inputs on my motherboard are starting to fizzle but I'm praying it's some check box in settings somewhere...
Intel i5 2500
gskill 8gb ddr ram
radeon 7770
h77m motherboard
