Cerb
So I built a machine for someone, and part of it is wireless networking. At my home, I can get a half-way decent signal from 30+ feet away, through several walls (WRT54GC, Zonet Ralink card). However, at the client's house, this is not the case! OTOH, here, it's only going through wood, basically.
The PC is in a corner, and around another corner in where the router is, connected to another PC and DSL modem. Going around the corner is the difference between a very good signal, and nothing (about 3 feet, but in the 'good signal' area, anyone could just step on it 🙂). Here's a diagram.
I'm thinking something like this, mounted around the wall near the router (which does not have an external antenna), would be a good solution.
Anyone have any advice, in general?
Is the router's internal antenna just not up to the task (IE, is it not coincedence the other WRT54s are $10-$20 more, with antennae)?
Should this solution work, just adding an antenna and moving it closer to line-of-sight (note that the PC itself is just as much of a problem--moving it out from the corner a bit helps the reception)?
If not, would two antennae work well (one mounted a bit away from the PC, one a bit away from the router), or would that be overkill (and more crap to look at--a mess!)?
Lastly, is there a better place to look than Newegg, especially for cheaper directional antennae?
