All: I need to connect 3 locations about 3 miles apart. Has anyone had any sucess with wireless lan/wan over these distances? (Don't want to break the bank on this one)
Thanks, John in Miami
I don't have any personal experience with this but I've heard some good things about the outdoor wireless solution by Enterasys. Check out: http://www.enterasys.com/wireless/
Breezecom will also solve all of your needs, If you need more then 11Meg, there are some (expensive) 100 megabit connections that use licenced and unlicenced bands.
