Wireless LAN connection keeps dropping
teknodude
I've got my laptop setup to connect (54g) to my Linksys Wireless router (WEP and MAC filtering enabled), everything seems to be fine except... the connection on the laptop randomly drops. It can be in the same room right next to the router with Excellent signal strength of 54MBps and then a message will popup saying 'No wireless networks available' - I then have to browse for wireless networks and reconnect.
Any idea what the problem is?
TIA for your help 🙂
teknodude
That seems to have fixed it - thanks! :-D I should have looked at the Linksys support before I was so quick to post!
Thanks again!
teknodude
