Wireless keyboard receiver
ArisVer
1,345
32
Hi. I have a wireless keyboard which is not responding anymore. I suspect the receiver and I want to know whether I can get a receiver for it and what I am looking for. It works at 2.4GHz but it is not bluetooth.
corkyg
Elite Member | Peripherals
27,370
240
What brand is that? Have you replaced the batteries? Does it have a module that plugs into a USB port? A photo of the backside would provide more info.
fralexandr
2,295
232
www.flickr.com
ArisVer
1,345
32
The links are great as I may end up getting one. Actually it's my brothers one that is broken but it looks the same as mine which is the one I pictured and has a model RT-MWK08 printed on the box.
I will try exchanging the receivers (modules) today to see if one module can work with the other keyboard. I was hoping to find a module that matches the keyboard if indeed that is what's broken. The keyboard has power.
