Wireless IP weatherproof cam
Dulanic
9,969
592
So I have a zoneminder setup with 2 cams inside. These work great but I want to expand to add 2 outdoor cams. I am looking for something that is WIFI and can work /w zoneminder (rtsp etc...). I know there is a crapload on amazon but there is so many fake reviews and cheap crap cameras.
I don't need something expensive or top of the line, just 720-1080 quality /w IR nightvision. Any ideas?
Needs:
  • WiFi (PoE might be doable)
  • Supports zoneminder (rtsp is most likely)
  • Weatherproof
  • Long power cable since it will be mounted outside.
  • 720/1080.
skyking
22,827
5,999
Axis makes good stuff, and I can always get it going quickly in zoneminder. I have about 10 different axis models and about 40 cams out there, along with analog and other brands. The Axis are easy.
