Wireless Internet and LAN won't work together in Vista?
ZoSo
Me and a friend use a shared internet connection. I use a Belkin USB Wireless adapter to connect to the Internet. But the only way it works is when I disable my LAN. If I connect to the wireless network while my LAN is enabled I won't get Interent. When I let Windows try to resolve it, I get the message saying to disable the other active connection. Once I disable my LAN I get Interenet. Never seen this before.
I'm running Vista Ult x64. I use windows to control the wireless, not the Belkin Utility, which doesn't seem to exist anyhow with x64.
Any ideas on how I can get my LAN and Internet over wireless working at the same time?
TIA
But they are not on the same network.
Windows IP Configuration
Host Name . . . . . . . . . . . . : Wireless
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : Ativa
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : Ativa
Description . . . . . . . . . . . : Belkin Wireless G USB Network Adapter
Physical Address. . . . . . . . . : 00-1C-DF-77-92-E8
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::2429:f3a9:353:5f92%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.2.3(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Monday, September 15, 2008 7:54:39 PM
Lease Expires . . . . . . . . . . : Friday, October 23, 2144 3:35:38 AM
Default Gateway . . . . . . . . . : 192.168.2.1
DHCP Server . . . . . . . . . . . : 192.168.2.1
DNS Servers . . . . . . . . . . . : 192.168.2.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : NVIDIA nForce 10/100/1000 Mbps Ethernet
Physical Address. . . . . . . . . : 00-1D-60-6F-51-4A
IPv4 Address. . . . . . . . . . . : 176.16.0.2(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Lease Obtained. . . . . . . . . . : Monday, September 15, 2008 9:05:48 PM
Lease Expires . . . . . . . . . . : Tuesday, September 16, 2008 7:41:45 PM
Default Gateway . . . . . . . . . : 176.16.0.1
DHCP Server . . . . . . . . . . . : 176.16.0.1
DNS Servers . . . . . . . . . . . : 176.16.0.1
Tunnel adapter Local Area Connection* 6:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter
IPv6 Address. . . . . . . . . . . : 2002:b010:2::b010:2(Preferred)
Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 13:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e50:2888:982:4fef:fffd(Prefe
rred)
Link-local IPv6 Address . . . . . : fe80::2888:982:4fef:fffd%13(Preferred)
That's the way it is supposed to work. Unplug your wired connection if you want to use the internet or remove the default gateway from the wired connection (which will most likely break that connection). You can't have two default gateways.
If XP could do it, for sure Vista can too, with a little more research I found out how to set it up.
Wirless network (internet connection) Set it to Public and use it's default gateway.
Wired network(LAN) Set it to Private and do not set a default gateway.
Works like a charm 😉
