Wireless Home Network...Help?
DealSpreeDotCom
600
Okay I want to set up a Wireless home Network...Now there a dozen or so setups that i can buy...what is like the best...
Linksys, aironet (Cisco), 3Com, Intel, D-Link, SMC, and there are others...
I am going to use it to surf the net around the house for the most part...
Thanks in advance guys!!!
~Roger
BigLance
1,206
Well, 3COM and Intel are probably the best, however, a Linksys product will work great and be quite a bit cheaper. NetGear is good also !
DealSpreeDotCom
600
Is there a big difference in brands...?
And if i buy a linksys access point, can I use it with a 3Com PC Card?
Thanks again guys?
sitka
895
How much are access points and say 6 Nics. I thought they were pricey. ie $1500
sharkeeper
10,886
As long as they all use the IEEE 802.11b standard you can cross brands with no problem
SMC has the best range of the affordable equipment.
Cheers!
DealSpreeDotCom
600
Linksys access point is $227 Pc Card $108...PCI Card $46...
Cheapest Combo Price...of equipment I have seen...
What is the difference in the range of the SMC and the Linksys...100's of feet or like 10 feet?
sitka
895
Those wireless access point gateway routers are cool. I wonder if they build one with a built in cable modem. Sure would be nice to get rid of the rental.
LordSandMan
738
I know some have better range than others. I think the Lucent one had a range of 500ft, but it was around $500 about a year ago. Don't know if distance matters or not.
DealSpreeDotCom
600
well linksys say range in 800Ft...someone said SMC is better, and i wanted to to know how much better...like 10...or 100?
jaywallen
1,227
Hi,
You might take a look at http://www.practicallynetworked.com/. I believe they tested the wireless routers from both SMC and Linksys recently. I believe they have identical internals -- except for the fact that the SMC includes a print server. You should be able to find information and even reviews on just about anything that's been discussed in this thread so far. Might help you make up your mind.
Regards,
Jim
jaywallen
1,227
Roger,
You're welcome. I hope you enjoy that site. There's a lot of useful how-to stuff as well as the reviews.
Regards,
Jim
