Wireless help please...
Geekling
682
I just setup a Linksys Wireless -G Broadband Router with a 4 port switch model # WRT54G and it works. Atleast I'm getting internet access on my computer using the switch.
But then I hooked up my Linksys Wireless -B Game Adapter Model #WGA11B and its not detecting it.
I was told these 2 are compatible. Are they not?
please help. I would like to use this ASAP.
Geekling
682
Wireless SSID Broadcast is enabled and I have Security disabled. Whats stopping it from seeing the adapter?
Anyone?
nweaver
6,813
Is the computer not seeing the adapter, or the adapter not seeing the network?
Geekling
682
It won't let me install the drivers for the game adapter. It searches for the network and it gives me the message...unable to detect gaming adapter on your network...
JackMDS
29,544
421
You game adaptor does not need drivers.
May be you should explain what your are trying to do with the adaptor?
If you router can not detect the presence of a game adaptor, make sure that it is installed correctly on what ever you are using it on, and put the unit close to the Router while you are trying the initial installation.
:sun:
Geekling
682
I'm trying to get the router to detect the gaming adapter so I can use it for my xbox :) but its not doing it.
