Greets all
I am craving some new wireless headphones as a belated holiday gift and was wondering what the concensus was on this board as to what are the best. I'm in the $100-$150 or so price range. I currently am leaning towards either the:
900 Mhz Sennheiser RS130's ($119.99)(http://www.sennheiserusa.com/newsite/productdetail.asp?transid=009925)
or
900 Mhz Sennheiser RS140's ($149.99)(http://www.sennheiserusa.com/newsite/productdetail.asp?transid=009927)
or the
2.4Ghz LTB WR-ST's ($159.99)(http://www.listentobelieve.com/ltb-wr-st.html)
From what I can glean the Sennheisers have better range--up to 100 meters and dynamically 18-22000 whereas the LTB model only goes 35 meters or so with 20-20000 dynamic range. Also the Senns operate for up to 22 hrs on AAA Nimh rechargeables while the LTB's run on an unknown size Lithium battery with a life of 4-6 hrs per charge. On the other hand the LTB's 2.4 Ghz band should allow less noise/static and better clarity than the 900 mhz.
Does anyone here have experience with wireless headphones and could recommend one over the other, or recommend another model? Thanks.
or
or the
