- Jun 4, 2004
- 2
- 0
- 0
Hello,
I recently bought a Linksys WAG54G and everything works perfectly exept wireless gaming.
When I play rise of nations online wired (UTP 100mbps) I have no problems.
But when I play online and wireless, I get disconnected after a certain amount of time, it fluctuates between 2 mins and 30 mins.
The wireless network works perfectly if I use it for just emailing, surfing, downloading,...
I did a ping command while I was surfing with this result:
Ping statistics for 192.168.1.1:
Packets: Sent = 1106, Received = 1105, Lost = 1 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 57ms, Average = 1ms
So no signs of possible problems when I play online.
I also did a ping command at the time I was being disconnected and then I could see very high ping times and timeouts:
Reply from 192.168.1.1: bytes=32 time=1ms TTL=150
Reply from 192.168.1.1: bytes=32 time=18ms TTL=150
Request timed out.
Request timed out.
Reply from 192.168.1.1: bytes=32 time=1784ms TTL=150
Reply from 192.168.1.1: bytes=32 time=67ms TTL=150
Reply from 192.168.1.1: bytes=32 time=5ms TTL=150
Anybody who knows a solution?
To make it clear: I have no problems when I do the exact same thing wired!
Request timed out.
Request timed out.
