My insane aerial.
That is the aerial I built for my truck. That post has a link to the site I got the idea from. Check it out. I think the aerial I built has a 18+ DB gain, but I have never tested it. If you go link surfing, someone built and tested a 802.11b link with 2 directional antennas ( like a dish ) that were able to connect to each other over a 28 mile ( that # is stuck in my head, but it has been a while, I may very well be wrong ) distance using only the outputed stock power from a linksys 802.11b gateway and card.
Be sure to turn on encription for any long hauls, or even short ones for that matter.
That link posted above is saying that I need a total of 63db to get 9 miles? That must be for full speed. I drop to 9k @ about 9 miles ( per mapquest ) so to get full throughput at 11 MBps I would need a 63DB gain?
<edit>
Oh, I see. those are for non-directional antennas. nevermind.
</edit>
