Originally posted by: magomago
http://www.steves-digicams.com...iews/pentax_k200d.html
so apparently it says there that it does
If you have the AF540GZ, there will be a setting to move it to wireless. I actually have that flash and the the there is a button that switches from "Off --> Wireless--->On". You obviously turn it to wireless when using it wirelessly
I actually use it with the cheap cactus wizards because I have a k100D with no built in flash
It costs a pretty penny, and you might be more interested in the 360 as its cheaper - and according to
http://www.shutterbudd.com/ite...360GZ%20Flash#resource it should also support wireless flash
