I was searching for extension power cord when I stumple on this.. oh wait, this have no cord. Excuse my 'stumple'. LOL
http://www.thinkgeek.com/stuff/41/wec.shtml
Warning: Even though these microwaves are about as harmful as the leakage from an ordinary microwave oven (not much), do not put computers, televisions, other sensitive electrical equipment, food, liquids, paper, glass, flammable substances, magnets, or living things in between the base and satellite units. Just in case.
Originally posted by: ChAoTiCpInOy
That was an April Fool's Joke. I can't believe your actually thinking about it and trying to decide wat it can do. Wow, I can't believe it still works even after all this time.
Originally posted by: f95toli
What is the power rating?
Transmisting power is easy, the problems starts when you want to transfer more than a few Watts. Not to mention transfer energy without losing most of it to heat in the process.
Moreover, IF that thing can transmitt more than a few watts it is probably illegal in most countries.
True. However, there is nothing wrong with the principle and it might be safe enough if you limit the power to say 0.1W, this might still be enough to e.g. turn on a LED and might be a fun technology demonstrator. This is what I had in mind.
Now, this HAS been seriously considered on a larger scale. I know there have been a few studies where they have been looking at beaming power to/from satellites using microwaves. One very futuristic idea would be to have huge solar panels in orbit and then beam the energy down to large recivers. However, once again safety is an issue; if the antennas are misaligned you might end up frying something which is generally speaking not good.
The other way (earth->satellite) might be a useful method to e.g. charge batteries of satellites and safety is less of an issue. However, AFAIK this has never been demonstrated.
Originally posted by: Talcite
sorta off topic... but how do those electric toothbrushes charge? there's no contacts between the base and the toothbrush.
I think I actually read about it in New Scientist (or a similar magazine) a few years ago, but now when you mention it I also remeber seeing it in Sim City.
It might be futurustic. However, solar panels in space is a nice idea. You can make HUGE panels without problem (especially if you use a flexible panel which you can simply "inflate", then you only need to balance out the radiation pressure) and since there is no atmosphere the energy density is somewhat higher than on the ground. BUT, you need some way to get the energy back to earth.
About microwaves: I don't think you would neccesarily fry the satellite. If you use a relatively high frequency (say 20 GHz) it is quite easy to shield the electronics (after all it is much easier to shield out 20 GHz than e.g, 20 MHz, some kitchen foill would be enough).
That said, it would still be a very inefficent way to transfer energy but in some applications it might be worth it.
Originally posted by: YahoKa
I'm not up on my quantum physics, but bascially isn't it impossible to focus it in a direct line? That is, won't the wave propagate in every direction anyways?
The problem with transmitting on the electromagnetic specturm is the combination of these two things: it carries energy in the wave/photons, and waves diffract (en.wikipedia.org/wiki/Huygens-Fresnel_principle)... thus you capture a fraction of what you sent. You could have almost perfectly efficient wireless transmission with a magnetic field (capture flux), but then you need really, REALLY big magnets, and you get rather obvious problems with that.
