Wireless Eduroam Problems
Jan 18, 2010
60
My univ grants access to Eduroam. Today I tried to set up a wireless connection using Eduroam, I have Windows Vista.
I searched for wireless connection, found one, added and it worked well.
After that I checked an icon in my taskbar and I had 2 Eduroams running: Eduroam and Eduroam 2
I then went to control panel>network management>wireless connections and removed the Eduroam connection (there was only one showing up)
I set up a new Eduroam connection following the procedures available by our University. The process went well and I was able to connect to the internet.
Once again I checked the network icon on the taskbar and instead of two, I had 3 Eduroams running: Eduroam, Eduroam 2, Eduroam 3
When I shut down one of them, it shuts down all.
I went to control panel>network management and sometimes it shows:
My PC ----- Eduroam ----- Internet
other times
My PC ----- Multiple Networks ----- Internet
Those multiple networks are all Eduroams, if I rename them to the same name they keep showing up... now I have 6 Eduroams!!!!
It am able to access to the Internet, the problem is, it seems that I am connected to several Eduroams instead of just one!
In control panel>network management>Wireless Management there is only one showing up and everything looks fine but after I connect to the Eduroam Network, instead of one connection I get 6 and It keeps ''adding'' Eduroams.
Is it normal? How can I reset those connection to get just one? Is it possible i'm connected to several Eduroams?!?!
