wireless docking of a touchscreen.
odror
I have a touchscreen monitor (works well out of the box with w8, Probably works with linux. I have to test it)
I would like to separate it from the PC. I am basically looking at remote docking.
I need wireless HDMI with 1080p support. (this is easy).
The problem is to find wireless USB to connect the touchscreen. I have search, but found nothing useful. First it is hard to search because of the confusion between WUSB (wireless USB) and USB wifi network adapter. Whenever I find something there is issue with Linux driver. My Linux kernel have UWB and WUSB modules. (May be I do not need a driver ?) Also many of the products that I found are either legacy or have low rating)
I have looked at iogear GUWH104KIT, GUWIP204
Cables Unlimited DisplayDock Wireless USB Docking Station with Video for PC
Any help will be appreciated.
Thanks
